- Joined
- 6 Apr 2013
- Messages
- 3
- Reaction score
- 0
- Country
I would appreciate some good informed advice on where to look for problem with one of my sisters showers which had "stopped working" after about 5 years daily use. I had a look yesterday and this is what I found.
She has a booster pump in airing cupboard which has a cold feed from attic storage tank, and hot supply from a standard cylinder. Both of the pump cold and hot outlets divide on a T in the pipework within airing cupboard to supply 2 thermostatically controlled showers. 2nd shower works perfectly without issue so pump and supply must be ok. 1st shower behaved as follows.
Headset held high on wall mount there was no water flow when valve switched on and no action at pump. I lowered headset to shower tray and cycled valve on/off , and it kicked into life easily. I ran it for 30 seconds and replaced on wall mount and tested and all was well.
Closed everything up and went for coffee. Fixed a few other "while you are there items and then before leaving I went upstairs to 1st shower again and there was again no flow .. slight trickle .. and pump kicked in for half a second .. I again lowered and again all was flowing as required again.
As this shower is not new and worked without problem for circa 5 years , head pressure cannot be an issue as I see it. As 2nd shower running from same pump outlets runs without problem pump cannot be at fault either.
Which leaves as I see it an airlock ( but after above 30 seconds should no longer be possible I think ) or faulty valve on 1st shower. However I cannot see such a fault anywhere relating to valves so I thought I would consult here.
Any ideas appreciated .. MJM
