Hi all,
Shower Mira Play, not heating up as it should.
It has three settings... Low, Med, High...
Low... no heat given at all, right throught the range...
Med... Temperature dial has to be almost at full to be nice and comfortable
(OVer time this has had to be increased to full to get heat.)
High... good solid heat right through the range, however when on for longer periods... ie over 5 mins it trips the mcb. (Not good running down stairs to reset it, esp when dripping wet from the shower)....
Any ideas on this? how it could be fixed.... I have spoken with Mira, got someone not very bright on the phone, and all they seemd to want to do is send an engineer out.....
Just in addition to this, the shower is wired, no more than 5 meters from CU, with 10mm cable, and 63RCD protected and a 40MCB.... This is the spec suggested from Mira, when installing this unit... the only difference is i have a fan running from the Shower switch.... could this push the 40mcb too far, hence the trip at high power? Would I do any harm in replacing the 40, with say a 45 mcb?
Im thinking ive got two problems here... whats you thaughts?
