shower problem
21 May 2011
i have a triton t80si shower which for no reason after a couple of minutes just stops , no water comes out but the low pressure indicator pops up .the pressure to the unit is fine so suspect the pressure sensor ??
if you leave it foe a while it restarts but cuts out again .the water heats up but not over heats and cuts out .
any ideas , please help
thanks in advance
low pressure indicates a blockage, try running the shower without the head.
faulty solenoid coil.
check the solenoid coil for resistance with a multi meter in it's failed state.
should be 3.4 kohms or above.
The problem occurred due to blockage or solenoid coil. Check out both the things.
Blockage don't cause a low pressure neon to come on water stop then restart again after a period of time. :rolleyes:
it's a solenoid coil fault.
thanks in advance
all fixed , it was the solenoid , £12 for a new one
