Hi
My electric shower's pull cord switch suddenly jammed and doesnt respond when i pull the cord. I have just got a new one MK 50A from B&Q and tried to replace it following the same way as the old one's connections but it doesnt work. No light etc.
I have looked at the guidelines provided but they are not helpful. The switch is the same type as the old switch (photo attached) but although the switch has space for 5 cables there are only four cables avaialbe
The swtich has space for the following
Supply L
Supply N
Load L
Load N
One on the side probably called neutral
There are four cables avaialbe
Black
Brown
Red
Green & Yellow
I have just used them the same way as they were in the old switch but the whole things doest make much sense. I have changed switches for light bulbs etc before but this one seems quite complicated.
The cables were set as follows in the old switch which i have repeated now
Supply L - Left blank
Supply N - Brown
Load L - Red
Load N - Black
One on the side probably called neutral - Green and yellow
Can you please advise. Thanks
Supply L
Supply N
Load L
Load N
Black
Brown
Red
Green & Yellow
Supply N - Brown
Load L - Red
Load N - Black
