- Joined
- 2 Dec 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi
I am looking for some advice I have a grundfos twin impeller 1.5 pump on a gravity fed system.
I have recently replaced the pump along with the shower mixer bar and head as when turning the shower on it would start up and then the water pressure would drop and the pump would become noisey.
The pump has been working for a few years before I encountered this problem. Pump is located next to tank in the cupboard with the piper work going into the loft then back down to the shower. It has a Surrey flange on the top of the tank.
I had a plumber out who seemed to think it was air getting into the system, I tried forcing the air out by covering the tap when the hot and cold both open but this did not work. I then removed the mixer bar and turned the shower on and it worked fine.
After replacing the pump and shower mixer it worked fine for a few weeks then the problem started again!
I can hear air but can't seem to keep it out. I don't have any air vents or non return valve on the pipe work.
This is driving me mad so any advice would be appreciated!
