Hi Guys
Have recently had a loft conversion built which will contain bedroom and new en suite. Everything has been installed in en suite but we are experiencing problems with the hot water supply to the bathroom in that it keeps getting air locked.
A new negative head shower pump was fitted to feed the supply. It is in the eaves of the loft directly over the hot water cylinder. Unfortunately I could not fit a Surrey flange to the head of the cylinder as the original fitting could not be shifted so teed off from hot water outlet pipe . I am aware that this is probably the reason for the air but need to know if there is a way of clearing the problem without tampering with teh cylinder. Did try fitting an air vent at the highest point but that has not really sorted it.
Would it help if I repositioned the shower pump so that it is sited at the base of the cylinder cupboard so that the hot water is feeding down into the unit and it then only has to pump up to the bathroom? Hope this makes some sense to you experts
