Hi
I about to get my bathroom redone with a walking shower and possibly a 200mm or 400mm Drench Shower Head.
I currently have a gravity system with Vented Cylinder.
The Cylinder is very old and on its last legs and needs replacing.
I would go for a unvented cylinder or megaflow but my mains is pretty low 12-14l/min and Thames Water have told that I would need to upgrade the street main which would cost £1500 - £2000 which is way out of my budget.
So I would like to upgrade the cylinder and fit a shower pump as my cold water tank in the Loft is 50 Gallons.
I need some advice
1. What size Cylinder should I get ? if I intend to use either a 200mm or
400mm shower head. There are 3 people in the house.
2. I intend to place the shower pump 4 metres away from the shower I
have a rough drawing up. As there are bedrooms next to the air
cupboard and just below the loft and don't want to be disturbed by
the pump in morning
If any one could recommend which type of pump I should be looking for?
thank you
Boiler is a 30K Baxi FS
I need some advice
the pump in morning
thank you
