I've been advised to change my 15mm x 3/4" pump hoses because they have isolating valves because they not being full bore.
Yet if I measure the bores on both the isolating and non-isolating hose they both have 8mm.
Advised to change to 22mm x 3/4" hoses, measured a non-isolating hose with a 13mm bore and a isolating hose with a 9mm bore.
Most hoses online such as Salamander and Stuart Turner offering isolating valve hoses, so why is 22mm pipework stipulated for most pumps when the inlet/outlet is restricted worse than that of a 15mm copper pipe with their 9mm bore.
Been searching for 22mm x 3/4" non-isolating hoses, very scarce to find any to make use of their 13mm bore to have max flow.
Any suggestions of online outlets for them.
