- Joined
- 3 Aug 2024
- Messages
- 3
- Reaction score
- 0
- Country
Hi folks, I've just moved from a flat to an older house, and there's a lot to wrap my head around regarding the plumbing, compared to the simple combi boiler in my old place.
I've got a vented cylinder fed from a cold water tank in the loft, and a positive head twin impeller shower pump fed from the cold water tank and the cylinder.
First (and most important) issue - the shower pump cuts out after about 10-15 minutes of use. No good for a longer shower or if two people want to shower in succession. I'm not sure if the cylinder is running out of water, or if the cold water pressure from the loft tank is too low to feed the pump and refill the cylinder at the same time. From testing the cold water tap in the bathroom with nothing else running, the pressure does seem to be pretty low.
One thing which might be important info - when the shower pump does cut off, I can still get plenty of hot and cold water from the bath taps.
Second - the hot water taps running off the cylinder feel scalding hot and measures at nearly 70⁰C, despite having the cylinder stat set to 45⁰C (I'm aware this should be higher for legionella reasons but for now I'm just testing). I know the water at the top of the cylinder is always going to be hotter, but this feels like a huge disparity. Is that normal?
Thanks in advance - I expect to be back here a lot with all the excitement and tribulations that come with buying a house from the 70s!
