Advice please!
Will shortly be adding a small stuart turner showermate pump in new bathroom installation.
My plan is for the pump to be located under the bath, as at the one end there will be a fair bit of space with some boxing in between bath end and wall. Screw fixed removeable panel etc. Not enough space in airing cupboard by cylinder unfortunately.
Query is concerning pipework arrangement and whether dedicated hot/water feeds to the pump are really needed. Normal cold and hot water with loft cold water feed tank (some 2.5m above), cylinder below etc. The installation manual of course requires separate dedicated supplies from cold and hot water tanks.
Intention is to have 22mm hot and cold feeds into the bathroom, tees off for toilet, basin and bath, and then into pump. All very close and within 1.5m of cylinder. Other outlets would not be used at the same time as the shower so I really can not see a problem with this if there are NRV on the pump outlet.
Also does the hot water tap off from the hot water cylinder really have to be with a surrey flange or essex flange rather than the normal top outlet where there is a good head - cold wtaer tanl 2.5m above?
Any help would be appreciated before I go ahead and then find I need to rejig as I got it wrong!
