Hello!
I want to install a shower pump under my bath. At the moment there is only lighting in the bathroom in terms of electric. What I plan to do is the following:
1) build a counter-top along the wall which will join the bath at the side where the tap is installed. This will incorporate toilet cistern and will be a base for semi recessed basin.
2) install shower pump inside this counter-top (it will be partially under the bath and partially under the counter-top; there will be no direct access to shower pump as there will be fixed acrylic screen under the bath and wooden wall under the counter-top)
3) under the floor boards there are cables going to 1st floor sockets. I plan to cut one of them and install maintenance free junction box (ashley) to get power supply for the pump
4) under the basin on the wall install fused 30mA RCD spur and isolator switch and connect the pump cord to it.
As a result the shower pump will be installed in the location which will be only accessible by tools and the only electrics which will be accessible without tools will be RCD spur and isolator switch behind the door under the basin (although I can cover them with some fixed panel if required).
Does this plan fit electric bathroom zones regulations? What part of this installation should be done by certified electrician?
Thanks a lot,
Sergey
Thanks a lot,
Sergey
