Am after some advice regarding an existing shower pump that worked ok before fitting new shower valve to an on suite.
When turn shower on no water flow, as soon as I touch the hot water pipes to pump the flow starts straight away, then is ok if the shower turned off and on again within an hour or so, all works fine, if left overnight, need to wiggle pipes again for flow . Only difference is new shower mixer valve is approx 300mm higher than before and shower head higher. Pump height has not changed relative to hot water tank. Pump at waist height.top of tank head height , approx 6ft.
Help would be much appreciated.
