over the last few months my shower pump has been taking ages to shut off after turning the shower off to the point where it is now not shutting off at all and i have to switch it off at the mains.
I used to be able to switch it off at the mains, leave it ten mins, turn switch back on and the pump would remain off untill next time i would use the shower, then it got the stage where i could leave the mains switch on but the pump would just randomly start at any given time, and now it kicks in as soon as the mains switch is switched on.
I live in a flat, the cold water tank is about chest height, the shower head is higher than this. I have a singe impellor (hot water) negative head pump which i located under the bath, it has worked peferfectly for a few years before i started getting these problems.
I have read about flow switches,booster adjustments etc but there is nothingobvious on the pump or on the immediate pipework that i can adjust.
I would like to try anything before going and buying another pump
Help / ideas would be much appreciated
