shower pump on/off switch
pld
11 Dec 2006
London
Hi All,
I have had a shower pump (showermate 1.8 bar) installed a couple of days ago. Originally, I was planning to have the pump to provide higher pressure only to shower however the plumber said it would be to complicated in my case due to the pipes position...
Anyway, now the pump is pumping everthing in the bathroom wc, sink, and bath (with shower mixer). This is really annoying because of the noise it makes and I don't need the extra pressure in the rest of the bathroom.
I was wandering if I can have a switch(on/off) for the pump so that I only switch it on when I need to take a shower? Will it damage the pump if it's off the rest of the time? Will the water go through the pump without a problem if it's switched off?
thanks!
No.
Not as well as if it didn't go through the pump. It might only be dribble, but you might be lucky.
Why not just try it? If you unclip the flow switch from the pipework then the pump won't start.
