Hi folks.
I,m installing a shower cubicle/sauna, and it needs a minimum of 2 bar. I have a 3 bar pump, which has 22mm connections, but the connections on the shower cubicle are 15mm.
The instructions with the pump say that "the outlet piping may be 15mm for a short run otherwise the performance may be affected." the cubicle is 3 meters from the pump. Would you consider this a short run?
There are existing notches which will take 15mm and I would like to avoid cutting more out of my floor joists.
Thanks.................Phredd.
