Hi, I am planning an en suite with a shower just below the water tank which feeds the hot water container.
When holding the showerhead high it might be higher than the outlet of the tank.
The cold water comes from the mains supply. I have been told that a pump for positive head will do, as long as I put it ar the same level as the hot water cylinder, which is on the floor below the new shower.
Does anyone have any experience with such an installation and can confirm this? Or will I need a pump for negative head anyway?
Thank You Tamrasi
Thank You Tamrasi
