Hi all
I wonder if anyone can help. I've got a problem with my shower pump. It is a Watermill Wasp 66 twin imp. The pump is working iratically it will come on with very low flow, I.e. A small turn of the shower tap, if I try to turn the shower on any fuller it cuts out completley. Similarly if I restrict the flow using the hot inlet valve to the pump, the shower will work. If I fully open the inlet it stops. I have bled the pump using hose from the fixed head and also manually bled it from the pump outlet so I'm pretty sure its not air. I have a 2m head so pretty sure its not low pressure. In fact it seems to be the opposite. Too much and it stops. If I turn it on very gradually it will come on at full power but eventually stops.
Any ideas would be most welcome as I'm at my wits end!
Thanks in advance
Thanks in advance
