Have a client whose shower pump seems to be drawing air into the hot side of the pump but I can not see why.
Set up is:
It works whenever I attend, flow measured with shower bar removed as 14 l/min on cold side 17 l/min on hot side and runs for long period. When customer uses shower runs for about 1 min before pressure drops and hot side of pump goes noisy as if air has accessed pump. Any ideas?
Set up is:
- Property is a one bed one bathroom property occupied by a couple
airing cupboard next to bath room.
hot cylinder in airing cupboard with tank mounted above it.
Salamander ESP50CPV negative head pump is on airing cupboard floor.
Pump is about 1 month old.
Dedicated cold feed from CWSC direct to pump.
Dedicated hot feed from hot cylinder via Essex flange with dip tube.
Shower bar is an Ideal Standard Alto Therm
