I've recently installed a new bathroom on the same floor level as a gravity fed hot and cold water system. I've installed a twin negative head pump as per the photo but still have problem with the hot water running through the pump. Cold water through the pump is fine. I've got a surrey flange fitted to the top of the hot water cylinder but the pump still sounds like it’s got air in the system and running the hot water at a much lower flow rate than the cold. Can anyone see any problems with the setup on the photo ? (from left to right: hot water in, hot water out, cold water out, cold water in). My thoughts are 1) That it may have something to do with the ‘T’ very close to the hot water pump outlet. 2) The feed from the hot water cylinder goes down, then slightly up (beside the brass elbow) then down again into the pump ? Any thoughts would be welcome. Thanks, Paul
//www.diynot.com/network/PaulWill/albums/
