Hi Guys,
I would like some advice for our shower pump. I have bought and installed a watermill PR50D regenerative pump, but I will give a brief overview of what we had done.
Several years ago we had a Mira mixer shower. We had a reasonable flow of water but it was always very hot, it was hard to get it to be comfortably warm. When we took the old bathroom out we capped off the pipes in the loft and have since recently decided to install a new shower.
We went for a thermostatic mixer (gainsborough GS500) shower in the hope that this would solve the 'old' temperature problem. It does seem to have done this but the pressure is quite low, we get a useable flow of water through but it's far from anything that would enable a quick 2 minute shower in the morning. So I decided to put a pump in the loft.
I should say in advance that with the pump not connected to the electricity the shower behaves exactly as it did previously so I don't think that there is a problem with any water flow through the pump. There is a large water tank in the loft dedicated for the shower. The waterline of the cold water tank is above the pump but the bottom is not. I don't think this is the problem (at least at the moment) but I thought I should let you know. The hot water pipe runs vertically from the hot water cylinder into the loft. The supply to the shower is tee'd off with the pipe continuing up and over for the overflow and also to avoid any air getting trapped (?).
I cut the pipes in the loft to the shower and connected the pipes to the pump. I ran the water through the pipes for 5 minutes and then turned on the pump. I could hear a noise which sounded like the coils were engaged, but the pump didn't kick in. Smoke then started to come out of the pump. I turned it all off. Confirmed that the water was still running through the pipes and then tried again with the same effect.
I then disconnected the pipes and then with the pump plugged into the mains I (very briefly) blew through the inlets (each in turn) and heard the familar pumping sound kick in.
Does anybody have any suggestions? I would really appreciate it.
Regards,
Brian
Regards,
Brian
