Hi, ive recently started work on my bathroom to incorporate a thermostatic shower mixer as previously had an electric shower fed from mains.
I live in a flat but have a loft space above us which I have moved the cold water storage cistern into, this supplies the feed for the hot water storage cylinder only and all cold water is off the main. The hot water distribution pipes run under a screeded floor to feed the bathroom and kitchen which presumably tee off underneath.
My goal is to instal a monsoon S2.0 bar single pump to the hot water so that the new shower mixer will receive boosted hot and mains cold, therefore more balanced.
My problem is that the only space i have to locate the pump is under the bath which leaves me a little confused about how to supply the pump from the cylinder. I realise that the cylinder will need a flange installed but im not sure which one?
I wanted to boost the hot immediately as it entered the bathroom (therefore boosting the basin as well as the shower mixer) but how do i go about this without interferring with the feed to the kitchen? I know the easiest solution is to site the pump next to the cylinder and boost all hot water throughout the flat but there simply isnt any room unless it is above the cylinder, can this be done?
Any help will be much appreciated, cheers.
