Hello all,
I have two Salamander CT50 1.5 bar shower pumps installed in my loft for the main bathroom shower and ensuite. My system is vented and the distance between the bottom of the cold water tank in the loft and the shower heads is around the 600mm mark, probably a little less.
The pumps have been in operation for a number of years and have recently developed leaks etc.
Instead of a straight like for like replacement I was hoping the group would have some recommendations, possible alternative pump models looking at long term reliability, noise levels etc.
I am also not sure as to whether I should be looking at a negative (universal) model, due to the distance between the tank and shower head?
I had considered changing the tank to a pressurised system but I have been advised that due to space limitations this is not an option.
