Hi all
We've had a perfectly working +ve pressure twin impeller single shaft shower pump for years. A couple of nights ago the hot out connector came free as I was showering!
I've screwed it back on and now it won't run unless on full cold. The plumber has been and can't see anything wrong.
We did however scratch our heads as to where pressure reducing valves should sit? Inlet/outlet/hot/cold/both? It appeared to only have one on the cold inlet previously.
Also, on looking at the pump I can see what must be the magnetic flow switches, I am assuming these should be on the inlet feeds? Would these be effected by not having the pressure reducing valves in the correct place?
Infuriating because I know essentially the pump itself is fine, just suspect it's a flow switch issue!
Any thoughts?
Thx
Any thoughts?
Thx
