Shower pump sizing
10 Jul 2013
Suffolk
PLEASE IGNORE POSTED IN WRONG PLACE
About to install a shower pump and was wondering what pressure people would recommend.
We're not looking for a massively powerful shower, just a decent flow through a standard sized head. We have two showers, but it's very unlikely they'll be used at the same time.
We have a 50 gal cistern and a 140 litre DHW cylinder. We'd like to be able to take a couple of showers one after the other without draining the water. can't decide between a 1.5 bar and 2.0 bar.
Bristan do a variable flow pump - but they look a bit pants, only rated for 20 mins use per hour...
Cheers
Simon
//www.diynot.com/forums/plumbing/shower-dilemma.329422/
And this taken from another thread I raised:
For a very good shower you would need a Stuart Turner pump.
http://www.ebay.co.uk/itm/STUART-TU...Cooling_Air&hash=item43a7ad6850#ht_1593wt_905
This would need to be fitted next to the hot water cylinder and have a cold supply from the tank a hot supply from the cylinder. Then have these pipes run to the shower.
Andy
Read more: //www.diynot.com/forums/plumbing/pipe-diameter-advice.326795/page-2#ixzz2acHkbQ4W
