In our new(ish) house there is a power shower and the pump is installed in the airing cupboard, outside any zones.
It was originally plugged in to a socket (upper ring main) on the landing via a hole drilled in the wall and 13amp fuse protected only.
I was a bit wary about it's installation so changed the socket to a 30a rcd (no other rcd's on our cu at moment) whilst I searched for an installation guide, which I've now found.
The *recommendations* are that it is wired to a dp 3amp isolator and rcd protected.
I've changed the fuse and really want to change the socket to a fcu (with rcd) as this socket isn't used for anything else, except it's on the ring.
Whilst I'm competent at the moment in *basic* installations is there anything here that would require notification of any sort?
Cheers.
Cheers.
