Hi have a steam/shower unit installed. Recently had problem with mixer valve so called out egineer. He removed the none return valves from the inlets on hot/cold of mixer valve. The unit is pumped installed by our plumber and when we run the shower the large tank in the loft starts to overflow through the overflow pipe also some of the water is luke warm, any ideas?
