Hi, I have a mains fed electric shower in an upstairs shower room that often won't work due to low pressure. It is a problem in the area that I live in.
My question is: I have a Stuart Turner Monsoon 1.5 bar twin pump sitting in the garage unused. Can I take a seperate outlet off my cold water tank, tee the two inlets, tee the two outlets, (as the shower only has a cold water feed) and then connect it up to the electric shower?
Or.. can I just use one inlet / outlet, leaving the other inlet / outlet un-connected?
I know I would be better off with a single inlet / outlet pump, but as I have this one at hand....
Any advice appreciated.
P
P
