Shower Pump
2 Jan 2007
Hertfordshire
Hi
Want to install a shower pump in my bungalow, dont have a lot of room in cylinder cupboard, can i install it under the bath and just simply T into the 22mm that feeds taps and conect pump to shower that way..
Yes you can fit the pump under the bath, where will the electrics be connected?
I would be fairly careful about fitting the pump under the bath as it can be difficult to get dedicated feeds from the cylinder and cold water cistern. Most people tend to tee them in under the bath which usually isn't the correct way to do it. You can also be restricted as to keep the hoses straight off the top of the pump if the bath is lowish.
I can be done but caution is advised and make sure you follow the manufacturers guidelines.
cheers
