I've just replaced a Showerforce Turbo pump which had given up the ghost, with a NewTeam Varispeed 50 (which New Team told me would just fit straight in, no plumbing mods required). The system is set up exactly like the diagrams show, with a head of about 2m for the cold water, and a head of about 1.2m for the hot (from the top of the HW cylinder to the base) or 2m if you count from the cold water tank). The shower head is about 1.5m above the pump.
The pump seems to turn on quite happily when the shower valve is opened, but sometimes is a bit half hearted, and I think only pumping cold water. If i hold the shower head down in the bath, as low as it will go, and then open the valve, it works propoerly, and pumps warm.
Are the two pumps activated independently? If so, is there anything i can do to improve hot water flow so it is enough to switch whatever switch needs switching inside the pump? Or am i doomed to a life of explaining to guests that they need to take the shower off the hook before starting the shower?
