Hi folks,
hadve a galaxy shower (neptune exotic)
had a minor drip from the flow valve (looked like it was dripping from the spindle bit).
Replaced the valve assembly today and fitted the new little o ring where it goes into the presure switch thing above and the main heater casing bit to the side.
But it's now pouring (and I mean pouring!!) from the join at the bottom to the solenoid assembly. (Screws are all tight and it looks to be sitting ok)
Is this a common problem when replacing the flow valve?
Do I just need to remove and reseat it until it doesn't leak, or do i need to fit a new seal at the solenoid assembly (didn't come with flow valve) or even fit a new solenoid assembly..?
Thanks.
Thanks.
