Shower riser rail. Help!
30 Mar 2021
Ireland
Hey. I’m trying to release the bottom of a shower riser rail so I can slide on a new shower head holder.
The problem is I have no clue what I’m doing. I’ve removed the caps on the top and bottom of the vertical bar to see what is holding it to the horizontal bars.
I thought I’d find some flat-head fitting I could easily rotate. Alas, when I crouch my 19 stone frame into the shower tray and crane my neck up with one eye closed, this is what I see...
I’ve no idea what tool I’ll need or where to go from here. Any advice would be greatly appreciated.
Thanks.
Probably need an allen key. 3 or 4mm maybe. Buy a cheap set and you should get one that fits.
