Hi - I have the stone shower tray which are fitted with riser legs.
It's to be installed on top of a new vinyl floor - then I thought, should I cut off part of the vinyl where the riser legs is standing on? My thinking here is since vinyl floor is soft and the riser legs may press down the vinyl floor over time? This would probably distort the enclosure?
Also - the 90mm shower waste unit I got with the tray - apparently the thread is not long enough to do any turning to tighten between the top part and the bottom part of the waste unit - do you know which waste unit with longer thread depth which could easily give a few turns of threading to seal the waste unit?
