Shower stopped working
18 May 2011
London
Hello
This morning our shower didn't work when we switched it on. I've checked the fuse and replaced it with a new one and that's fine.
Take a look at the photos below. The shower is totally embedded in to the wall with tiles on top. So I'm not sure if there's any thing I can try myself or who to call.
If I call an electrician will they be able to get at what they need to, or will it involve getting all the tiles off the wall first?
The plug for the shower comes out of the wall in the next room and plugs in to the wall. This was how I could change the fuse.
Many thanks for your help!
You don't say what type of shower it is.
Is it an electrically pumped shower?
A shower that works directly from the hot water tank.
A shower that works directly from the combi gas boiler.
I will assume for the moment that it is an electrically pumped shower.
While you have changed the fuse, I assume this is from a fused connection unit close to the pump and not the Consumer Unit.
What type of fuse/MCB do you have at the Consumer Unit? And are you sure that this or the RCD hasn't tripped?
Do you have a multi-meter or at worst a volt stick?
It's definitely an electrically pumped shower.
Regarding these bits:
Not sure what this means but can't access the pump since it's under the bath which is all tiled in.
Not sure what this means either. But the plug socket that it gets power from is working fine.
I guess I need a plumber? Does anybody have any recommendations? I'm in East London / Hackney.
Thanks for all your help.
Yes, its a mistake to make the pump inaccessible, but it can be replaced with a different type of removable panel. To replace a pump is quite easy, just make sure you get the same specification, assuming the water supplies are easy to isolate...
Edit: so previously you could hear the pump running, but now you can't?
