Hi, planning to fit a shower in a new 1st floor ensuite roughly under the cold water tank in the loft. On a gravity fed system with the hot water cylinder on the 1st floor (opposite end of house from the cold water tank). Can I supply the hot feed to a thermostatic shower from the hot water cylinder expansion pipe (22mm) in the loft before it rises up into the cold water tank? If so are there any recommendations as to what height or where it would be best to connect to?
At the moment the pipe feels cold but I'm guessing that’s because there isn't any water flow and would warm up once there is?
Many thanks.
Many thanks.
