Hi Everyone (and anyone who can help)
I bought and installed the shower SV1013 through Ibath on Ebay.
the problem is the thermostatic bar does not get up to anywhere near 38 deg, even on max.
I have then taken off the end caps and exposed the brass temperature cartridge to try to adjust the settings. The problem is that the unit will only turn a certain amount and this is still not above luke warm.
If it helps, the cold is directly off the mains but the hot is off a combi.
Is there any adjustment which can be made if I actually take out the temperature cartridge? or is this a sealed unit?
any help would be greatly appreciated.
Thank you
Thank you
