Hi - I've had a Siadaw shower with thermostatic mixer in for about a year now and it's worked fine until recently.
I am now having problems getting the same amount of heat out of the shower and the pressure seems a bit lower.
I have a dedicated hot water feed from a valve on top of the tank.
I have a Bosch pump for the shower to boost pressure which seems to be fine.
I have removed the thermostatic valve and checked the water pressure for both hot and cold which seems fine (although I cannot compare with previous pressure when this unit was working ok).
I have blown through each side of the thermostatic valve along with the shower head etc and they seem to be blockage free.
One thing that I have noticed is that when I turn OFF the hot water tap in the bathroom after some use, the pump for the shower briefly kicks in for about a second.
I think I need some help???
