I am putting in a 10.8kw shower with 10mm cable of 7mtrs with a 50a dp pull cord with a63a 30ma /50a mcb /rccb can i run the rcd to a spare 30a fuse or a 45a if i can get one ,the run to the rccb to the cu is only about 15" [/b]
