Shower Trap
24 Feb 2023
I am having trouble understanding which shower trap I can use with my shower tray. The hole size in my tray measures 60mm but for the life of me I cannot find anything that resembles this when I search for one.
I have searched these forums and seen similar questions to mine but none of them have an answer other then a link to a catalogue which dose not answer the question.
McAlpine products are my preferable choice but when looking at their range online I don't see anything that mentions suitable for a 60mm hole.
Any help would be appreciated!
That's an odd size ,are you measuring the hole accurately? A 50mm waste fitting and
seperate trap Is probably what you will need.
You'll probably get away with a McAlpine STW type shower trap, they normally fit a waste hole size of around ~ 52mm and If I remember rightly the lower seal and flange are always larger than the top flange so are at least 70mm so should cater for a 60mm waste hole. 60mm is a strange size though as suggested.
What diameter is the depression for the waste as they come with different flange diameters.
