I realise it's a common problem to have leaks around whee shower trays meet walls, but I'm looking for a cheap solution that might be a bit different to other things suggested.
Basically, I have a shower tray (no up stands and curverd around outside and inside), a small gap and then tiled walls where the tiles go down just below the level of the tray. I've tried everything to seal it - massive loads of sealant, l-shaped pastic pieces etc., and currently have 2 layers of sealings and yet still it leaks.
The only thing that works, is to take 3 strips of polathene, and selotape then at the edges of the tray and on the tiles. Obvously, this doesn't look very good, but as it works, I was wondering if there was any product I could which would achieve the same thing? Basically, something to form a skin that cover the area starting from the tray to around the walls?
TIA
TIA
