Shower tray not perfectly level
1 Sep 2019
So I'm currently renovating our ensuite and I have just laid down a new low profile shower tray, 1200x800.
Bedded in a thin layer of mortor as recommended but it's marginally off level. When I say off level, the bubble isn't perfectly center, just off one line with a small gap in between.... Not touching the line.
Poured some water in the tray and it runs into the trap as its meant too. Worried that as its not perfectly level that once I get the shower in and the flow rate is upped, it will come back to haunt me. Does level really mean perfectly level or is there some tollereance?
Is the risk here the water overflowing to tray?
Did you take the level off the upstand or the base, could the base be slightly "un level" to help the water drain.
I'd get it level if you hanging sides on it or a door it'll need to be right especially when you tile it.
Scaff
Yeah, there is a fall built in to the base so the water will drain towards the waste, but the body of the tray (top edges) should be as level as you can get.
