is the upstand all the way round? I have fitted trays with upstands into walls only, that are tiles over later. I would recommend you follow the manufacturers instructions, sealing on the outside possibly, but (usually) never on the inside.
The size I am buying has 3 or 4 upstands although as you say I would prefer just 2 as it is going in a corner. With 3 or 4 the door and end panel would sit inside the upstand which would make it hard to seal but is it necessary
