- Joined
- 22 Nov 2003
- Messages
- 5
- Reaction score
- 0
- Country
I would like to change my shower tray, re-tile surround etc, but am having trouble finding a tray to fit into the recess which is precisely 850mm x 850mm. The original tray is smaller, 750 x 750mm and you've probably guessed it by now, the shower put in by the original (bodger's), sorry 'builders' made up the gap with a tiled shelf at tray level and it leaks. surprise, surprise!
I have been trying to find an 850mm x 850mm tray, but with no luck. The nearest I can find is 900mm x 800mm, which would be ok, I think, as I could use the 900mm width and 'let it in' 25mm each side. However the walls either side are plaster-board with studding which I may have to chop out a bit to slide the tray in. Is that OK? Anyone got any other solutions?
Regards
Laurence
Regards
Laurence
