I have a Triton Opal II 10.5kw shower, not sure how old it is (it was here when we moved in a year ago), which has three heat settings - a cold one, a medium one (one red mark) and a hot one (two red marks). In winter you need it on the hot one.
Anyway, this morning the shower cut out while in use, and when I went and looked the fuse on the consumer unit had tripped, as well as the RCD which I think protects that and a few circuits (everything except the lights, really). I switched them both back on and tested it again, and it works fine on the cold and medium settings, but instantly trips the two switches again as soon as it's turned onto the hot setting.
For some background information, Triton services replaced a heating element for me about five months ago. The shower has worked fine since then. I would think maybe it was the element again, but it's a bit different this time... last time, the shower still worked on the hot setting, it just wasn't actually hot (it was the same as the medium setting), whereas this time it just shuts off straight away.
Any ideas? Could a problem with the element result in a different behaviour like this, or is there anything else it could be? Also, just out of interest, since both the fuse and the RCD tripped - will one always cause the other to go?
I'm thinking it might be time to get a new shower, but I want to be sure it's actually the shower at fault first.
