Shower valve elbow: problem removing non-return valve.
Because there is minimal flow of hot water and the NRV is (conclusively) not working - not springing at all. There does not appear to be any grit present to have 'jammed' the valve hence the replacement.
Soak them in limescale remover (Killrock or Ataka 50:50 with very hot water) for half an hour then try again - or indeed they may be working again without removal.
They're out now and the new ones are in - what a bυgger, though. I ended up using a tiny drill bit to make some holes in the remaining base section of the valves and then 'twisted' the remnants out with a slim chisel.
Thanks for all the advice. ;)
