Shower wall Panels?????
28 Dec 2003
Not sure if this should be in “Tiling” as it’s an alternative, but has anyone done a Full Bathroom in this stuff?
Should I or is it batter to Tile for any reason???
Must admit, we do like the look of it. Some of it looks like solid Marble & no grout etc.., the only thing we DON’T like is the horrible Aluminium Extrusions in the Corners.
Would it be possible/advisable to butt the panels up tightly in a corner & use a bead of Silicone Sealant??? I would seal the edges of the board first too. I just don’t see the point in putting up something to look like Marble & spoiling it with something that looks like it belongs in the works bogs!!!
I did a shower cubicle in these panels a few years back. I just siliconed the internal corner as you said and it worked out fine.
Thanks GCOL
Have you ever seen a full Bathroom done in this? I'm worried it might look tacky. I think it looks fantastic in the small areas I've seen it in, but can't picture it in a full room.
Any ideas where I might get to see a full display? I'm in Merseyside so anywhere in the North West would do.
Thanks again!
Well they've got it in my local kebab house and it looks ok. :LOL: Apart from where the p*ss heads have knuckled it!
The only thing you need to be careful of is if you need to cut one of the boards vertically. If you leave a thinnish piece it can bend which will make it difficult to hide the joints. Certainly though, if you fancy it, go for it.
