Shower/washing machine - water pressure problem?
Status
Not open for further replies.
7 Jan 2007
Leicestershire
Hi there,
Not sure if these two problems are related. Over the past few days both my electric shower and washing machine have stopped working. The Titon Topez T80l shower won't emit any water and remains on the autoreset light when turned on. Sometimes if left on it will emit short bursts of water ( I can usually hear the sounds from the pipes when this happens). The washing machine won't fill with water when turned on. Having checked the instruction booklet, it says that there could be a problem with the water pressure. I have subsequently checked my Vaillant Turbomax Gas Boiler and have noticed that when the central heating is off the pressure gauge is below 1. When the heating is on it is just above 1. Is this a water pressure problem, and if so something I can fix myelf? Many Thanks
No, the cold tap pressure seems to be fine. Have noticed that the hot tap for the bath lacks pressure at times though.
Status
