shower waste and bath waste crisis
11 Sep 2016
had a horrible plumbing job done last year just been dealing with it now its need urgent fixing
other than the leaking shower trays on all corner and plaster on wall a cracking on stairs due to wall being weakened or moved due to wetness.
the bath waste pipe and shower tray is on one pipe when i pull the bath on the plug the water is pushed into the shower before it was just a small amount now after trying to plunge the bath a little as it was blocked the backflow is huge!
when i plunge the shower the bath gurgles the water flows then when the gurgling stops the shower wast stops flowing fast.
theres no slope the lovely plumber left a nice straight line of pipe. one could argue a slight incline sadly
i cant access the pipe work under shower but i maybe able
to access under the bath
perhaps i can run the shower waster seperatly outside as a single pipe ?
i cant rip out and start again any suggestions of valves or pipework i need to add im a amatuer DIYer help please
Got to say that's shocking! Just can't imagine any plumber fitting the wastes in such away were you get a back flush into the shower.
Yes you can rerun either the bath or shower waste. Or employ a plumber.
