can someone advise me, can i run the 10mm2 cable up alongside the water pipe that feeds the shower unit? if i run the cable above the copper pipe and compression fitting ,then water should never be able to run up the cable and get into the conections???? otherwise what to do? also the cable is in free air up to the point it enters the shower area, will keeping the cable behind the tiles for about 1.5 mtre of its 15 mtre length be ok? any advise welcome
________________________
moderator
post moved from UK electrics
moderator
