Hi Can I run a 8.5kw shower on a 6mm cable?
Are walls insulated where the cables run and does the cable run in trunking or conduit at any point.Hi thanks, its flat cable which is clipped direct to the wall and behind the plaster.The cable run to the board is about 8 metres long.
I.e. 70° Thermoplastic reference method C (clipped direct and/or buried in masonry).6.00mm flat twin&earth cable can carry a maximum of 47A that is providing there are no dertaing factors to consider.
