Showerforce 2000
11 Sep 2007
Old showerforce 2000 power shower, power fed from Transformer in loft.
Fuse in the transformer keeps blowing, suspect either dodgy transformer or pump unit in shower itself.
Do any of you guys think this may be the case as dont really want to replace with new power shower due to cost?
The shower worked fine up until a few weeks ago, the hot and cold water is coming through fine under gravity, just no power!
thought also, could maybe be the PCB in the shower causing a problem.
Hope someone may have had a similar problem!
hi im having exact problem with this shower at min did u suceed in getting it fixed????
